Thanks so much everyone for the kind words. I do need some help though.
I can't get the displays to work with my Beocenter 2300. However, they work perfectly with my Beomaster 4500. I've wired up an adapter just like the one IkeA bought from B&O:
Left side:
Pin 1 -
Pin 2 - Outside of RCA
Pin 3 - Center Pin on RCA
Pin 4 -
Pin 5 -
Pin 6 - Pin D
Pin 7 - Pin C
Pin 8 -
4 pin RCA from solder side:
o A not used
----- B not used
o o
C D
Right side:
Pin 1 -
Pin 3 -
Pin 4 -
Pin 5 - Center Pin on RCA
Pin 6 - Pin D
Pin 7 - Pin C
Pin 8 -
o A not used
----- B not used
o o
C D
I've traced all the connections and this connector should (and does, with the 4500) work. I either have a fault with my 2300 (which I have no other speakers with a display to test with), or some incompatibility.
Any thoughts?
