Hi Eric.
A few pictures of my Pentas pre the new skins from B&O.
Wrinkle on back of LH Penta.
Wrinkle on back of RH Penta. Needs a new top cap as well (from B&O).
Re-rubbered Mids. Missing the skin I peeled off and measured.
I
started with gluing the ID to the cone. It helps if you stretch
(slightly) the inside flange rubber. Experiment... This causes
the ID to be "larger" than the “Roll”. Hence the inside flat part tends to
follow the cone angle... I discovered this while wrestling with the
first surround trying to constantly separate from the cone while it was drying. The rest
worked like a charm.
"Chrome dome" on a BM 5500!
This
is a picture of my “Shop Amp”. A rescued BM5500 that needs help
starting, due to most likely, a defective relay. It starts very quiet
and after a second start the sound comes on as it is supposed to. It also
squeals when shifting from CD to Tape to TT to Radio???
I tried the alsacorp.com FX Chrome on the BM5500 and it shows every defect under the new skin. I’m glad I didn't skin the Pentas with this. The FX Brushed Aluminum or FX Brushed Stainless would be more forgiving.
Yes
the speakers in the background (LH) are a pair of RL60s that I rebuilt
the passive radiators and the crossovers on. They really rock now. The
other pair in the RH corner are a set of BL6000s that I’m waiting on
surrounds for from Holland. These will be my second pair of BL6000s
that need to re-rubbered!
I’ll
send you picks of the finished Pentas. I ordered Silver speaker cloth
for them and I will see how that works out.
If they look like junk with
silver, I’ll put the darkest black cloth on them to make them match the
BL6000s.
The PDF file is on its way via Email.
Enjoy.
IkeA
