Room with tv and beomaster:
1) Beomaster 4500 sw 2.1 two way
2) 4500 CD player
3) 2 Beolab cx 100 connected to avtive output socket in Beomaster 4500
4) Beovision 7-32 with no dedicated speaker of any kind - the concept was to be able to afford the Bv7-32 without the very expensive 7-1 or 7-4 and then use the Beomaster deliver sound through its speaker
5) All link speakers are ir-wise lighttyear away
Only - I have tried 20 other combinations - option combination that gives me tv sound is BM4500 AND tv in option 2
Thank you very much for your help, Peter. Sorry for being so difficult. You must be giggeling thinking "this is why b&o is for men and not female nurses". But thanks for your time - greatly appreciated.
Kind regards
Louise
