New tube for Beovision Avant 28"
Many thanks, Marc! Now, where did I put my Sencore 7000? 😕
I'll pass this on to Simon, see if he thinks it's possible and whether he has the tools - if this works this could be a very useful procedure, as you say, there are many sick and dying Avant's out there and it would be nice to be able to expand their lifespans. It's either this, or find out whether there is any other tube (eg Philips) that can be used to replace it.
Don't forget.... this takes a certain "feel" to do, as well as knowing what the particular tube type can take.
As to replacements, similar tubes can be swapped.  I do this a lot.  They have to be in the same family, but it's also possible to
make a custom socket adaptor if the pins are different.  The basic voltages need to be close to avoid modifications to the set itself.
A good "old school" tv guy should be able to do all this.  Pity that modern techs are mostly board swappers.
Thanks Marc for the clear explanation.
What it also needs to find an affordable replacement tube is specs of the original and replacement and the thing is: (well, at least with the TVs overhere) up 'till the Philips widescreen tube with it's troubles we never ever experience broken tubes, the 4:3 ones, i fixed all kinds of tv's over the last 30 years or so and if i ever had 3 broken tubes....that's about it.
So nobody 'digs' into this matter....
And than there's the physical fitting: the S-flat replacement for the T8111 is supplied with some bushing to make it fit.
If you add up all this experimenting, modifying and chasing data etc especially for the T8111 it again isn't worth it imho.
However, the experiment with 'burning' the shortcut out so to speak (or fit a 'transformer') is a good one: nothing gained, nothing lost...:).
But to find this nice tube analyser you mentioned overhere....ust any picture tube analyser is already not so common (probably for the reason i mentioned earlier: no need for it).
Is it adviseable to put the tube forward (screen facing floor) when doing this ??
I also heard of people heating it and tapping it...
Yes, you can heat and tap it as well.  But not too hard.....
Some people face the tube down, the theory being that any contaminant will fall harmlessly into the bell.  However, between the cathode and the front of the tube is still the entire electron gun structure, so this probably doesn't actually work.  I never do this.  I shoot tubes with the back off the set sitting normally on my bench.  Worked fine for 20 years.  The only difference is that I have modified my procedures over the years to reclaim heater to cathode shorts which "cannot" be removed by zapping it.  (A high current discharge between the cathode and filament WILL burn away the short, but blow open the filament at the same time.)  Anyhow, you have nothing to loose.  In cases where a CRT is still "OK" but a bit soft, I refuse to shoot it.  Since it's still entirely watchable, the risk is too high.  But if it's really hosed..... sky's the limit.
Marc
Yeah, i think i can give it a try with a normal power supply to try the 'heather' trick on the broken T8111 and see....
Don't exactly know when i have time (and a power supply) for this but will surely post my findings :), it's very interesting though reading your experience and the way you deal with it, especially overhere the Avant get's 'undervalued' because of this whereas even a good old 50Hz type is still a great tv to use nowadays so an affordable fix is really wellcome :).
