Does anyone know if the loudspeakers in an MX3500 are still available or an equivalent or a repair kit available? Dreaded foam rot!
MX 3500 speakers
I tried everywhere to get replacements having been told B&O no longer stock them and the German manufacturer no longer produced them. After doing some research I found they were available from a Chinese manufacturer via CPC distributers in the UK. They are the same apart from the connection "tags" which are located in a different position which I modified to the original location. The overall size and mountings are the same as the original units. The price from CPC is 11.17 each +VAT which I think you will find is considerably less than the B&O units when they were available.
Ron
Hi Ron
That sounds interesting. I don't suppose you have a product number or something else to go on as they have many many units on their website? Any loss in sound quality with them?
Hi Boefile7
I got the speakers u need. Where do u live?
Best regards
Trigi (Denmark)
Hej Trigi
What do you have? Are they from an old MX3500? I have only just got home so haven't had a chance to source replacement units yet.
I am in Stockholm!
