mcl wiring
I have an MCL which is missing the phono plug that connect sthe 8 core wire to the beomaster. Does anybody know which wire connects to which pin on the plug, and where can I get hold of a bare conector. I live in Leeds.UK.
Hi Simon, You may find
Top man.  May the birds fly upsidown the next time you wash your car.
πŸ˜‚πŸ˜‚πŸ€’
Simon, is it the MCL Speaker plugs you are after to connect to the Beomaster. If so these were available from B&O dealers. Last ordered some about 2 Years ago. Cost about Β£5 each if I remember correctly.
CraigπŸ™‚
Thanks for the reply, I am deffinatley going to buy them. I bought a 7 pin din plug from Maplins thinking I would have a go myself.... I melted the plug holding on the soldering iron too much.
