Both versions are commonly seen (well, as common as these get, anyway).
There were two different chassis versions (mainly due to a change to CL6 output valve
instead of CL4, I believe), and I'm almost sure that the default stations were
reconsidered at that time.
You can check if yours is the early version with the CL4 output valve.
The one on my bench is a "version II" as B&O calls it in the service manual, i.e
the "later" version with CL6.
Having said that; The pushbutton station selectors each covered a certain frequency
range and any station within that range could be set to the given button.
You could not change the range though, this means that not any button could be set to
any frequency and all "re-programming" of the buttons would have been done at
the repairshop where correct instrumentation was available.
And the tuning stayed correct for years.
My guess is that buttons with non-default station names could be ordered from B&O but
I haven't been able to confirm this.
It may not appear very convenient seen with modern eyes but to just be able to
select a station at a simple push of a button was hot news back then.
Even a child could change station.
