I am experiencing an odd problem with DVD1's and my "new" MX5000. The MX5000 had all capacitors replaced a year ago. I connected a DVD1 Mark 1 via SCART cable to the MX5000, and it worked fine after I set the MX5000 to Option 1. I also have a Beosystem 7000 connected via an AUX cable. Later, when I was sending option commands, the DVD1 stopped accepting commands altogether, and in fact would not even go to standby when the MX was commanded to standby (this with either a Beolink 1000 or Beolink 7000).
I swapped my DVD1 Mark 1 with a DVD1 Mark 2 that was hooked to my Avant. The Mark 1 worked fine when connected to the Avant via RGB, S video, and separate datalink cables. And the Mark 2 worked fine with the MX. So I thought there was something wrong with the DVD1 Mark 1 and the SCART.
Well, while troubleshooting an issue with simultaneous two-way communications from both the MX and the Beomaster 7000, I sent Picture Option 0 to the MX. And then the DVD1 Mark 2 stopped working right after ward! I sent various combinations of Picture Option 1, V Opt 1, and even got out my Beo4 and followed the DVD1 instructions for sending Video Option, Tuner, 1. Nothing works.
So my conclusion is that sending the option commands is somehow telling the MX to stop relaying remote commmands to the DVD1, or that some option command went to the DVD1 to tell it to stop responding.
Any ideas how to get my DVD1 back working again?
