Just bought a Beolab 5000
Well done! You're making me jealous now!
Very nice indeed.
Now with Beomaster...
To be done: changing the hardened rubber feet, sanding and repainting the Beomaster bottom plate. There is rust around the rubber feet, caused by the rubber itself degenerating. The feet are riveted, unfortunately. I will have to thread the plate before spraying.
I'll also have to find the special FM connector...
@ Step1: you wrote you replaced the amp trimmers..do you mean the level pots at the bottom ?
Because i'm working on Leslie's and noticed one of the phono level pots is broken i'd like to replace it but this seems like almost impossible to reach...
They're located under the switches, it looks like one has to take the whole amp apart which is a disaster with all the tough wiring and no connectors...:(, so i was wondering if and how you managed..
No I didn't replace the level trimmers, as these were fine after a clean! Not sure what advice to give but it does kind of look like a commited job! BTW If you find a new source of these overly large pots then let me know out of interest.... I guess Dillen / Frede are the folks to ask though!
well...accessing them/being able to replace them seems to be the first and major headache.:)
I did email Frede with a pic of the, in my view, impossible quest but so far it has been remarkably quiet...
Well, let's see if someone knows the answer..
I must admit to being a little afraid too. My Beolab works as it is, so I haven't opened it yet.
I did open the Beomaster tuner though! Nothing fearful here. I had to do much cleaning, there was a layer of white powder (
Here should be a pic of the switch mechanics, seen from top, below the small pcb which can be flipped up.
The pots are located straight under the metal parts of the front switches and it seems not possible to reach from the bottom part of the beolab...
right under the metal parts with the springs (switch mechanics) is a plastic foil, under it are the pots...:(
Are you sure that the PCB won't lift up from below, after you unscrew the bottom plate?
