Hello.
No, I'm not asking for a Glass Panel for my BeoChord. It fell out, but is still 100% Ok.
I just want to know, which glue to use to put it back in, without damaging anything.
With kind regards,
Harald Henkel
Hello.
With kind regards,
Harald Henkel
do not use glue! Instead use a good quality double sided tape. You have to remove the plastic moldings which held the glass. That is really simpel; look at the bottom of the beocord you see a small hole marked with an arrow, stick a paperclip in it and slide the plastic trim to the left. Now you can remove the cable connectors.
Clean up those plastic trims to remove all resident clue for a better stickyness. Because B&O used conducted paint, the height between the glass and the rubber underneath is important for a good working of the touchpanel.
Yes,
Thanks a lot Stonk and Paul.
I just ordered that tape.
I will report back when the tape arrived... ;-)
