This may not be the correct forum but i will give it a try.
Wanted a Lab 7.1 as a centre speaker for my Beovision 4 set up but can't justify to 2K spend.
So, got hold of the empty shell of a 7.1 and a front cover and want to try to do a DIY job.
Any comments or advise would be great i'm happy to buy the woofers, midrange and tweeters so they fit correctly, any suggestions as to an amp or amps that could be fitted to drive it ? powerlink in so I get auto turn on / off would be good.
My initial plan was a or a couple of second hand beolink passives or MCL2p's ? may not be powerfull enough.
Or maybe someone knows of an amp from another manufacturer that may fit the requirements ?
I look forward to comments.
Regards
