Well, I got everything on the mechanism back into it's rightful place, then got the mechanism itself back into the case. Got the two PCBs screwed back down, and got the solenoid clip back on. So all that's left is to put the keyboard and the plastic back onto the top of the deck. Except you have that belt to the timer that's connected to the keyboard.
I couldn't get it to stay. Took many tries.
When I finally had the keyboard and plastic back in place - and I thought the belt was in place - I flipped it over to screw it back together. Except the wood was broken in a corner. Oh well, fix that later.
Flipped the now assembled deck back over and plug it in. Put a tape in. Hit play. Deck engages for a second then stops. Try fast forward and reverse. Works a little, then stops.
I remember reading this fault may be because the timer belt isn't working. So I take the plastic back off, then peak under a PCB by bending it a bit. Sure enough, that stupid timer belt isn't attached at the mechanism. I bend the PCB a bit more to try to see if I can see if the belt is still attached to the keyboard underside, and....
...the PCB snaps apart!!!!
Two lessons learned:
1) Never take shortcuts. Disassemble the darn unit completely again to check on the belt. Never, ever, bend a PCB. God! I know better than this!!! What an idiot I am.
2) I am not up to this task, because apparently I'm stupid and take shortcuts (see #1 above).
Well, I'm going to take a shower, cook some dinner, cool off with a few cocktails, and try not to think of this afternoon's EPIC FAILURE.
Perhaps tomorrow I'll check the PCB. Maybe a bit of glue and some resoldering can fix it.
