Hi Premiumverum
Very well spotted :D
Yes I used 10uF tantals in the preamp to replace the 10uF electrolytics in the signal path. I couldnt find any film caps that would fit the spacing on the preamp pcb. The input caps on my "new" output amps are 4.7uF wima film caps as you noticed.
My policy through the rebuild of my BM8000 was that I used ceramic caps up to 1uF and film caps from 1uF to about 10uF if there is space enough on the pcb. For higher values I use tantalium caps or electrolytics in the signal path if I cant fit ceramic or film types. I like the tantals more than electrolytes.
/Fredrik
