Another step forward.....
Now its been time to assemble my new displayboard (module 8). I used the 7 segment displays from the old board but I had to take them apart to change the segment LEDs inside them. It is a well known problem that the segments go out one by one as time flies. This is discussed in another thread in this forum. The LEDs I have used will light up at a smaller current than the old ones so I needed to change the resistor values to the segments both on module 8 and module 9 (CPU) to get the display brightness right.
When I examined the old displayboard I saw that there was a burn mark on connector P75 pin 12 which is the power feed to the display board. These connectors will wear out and loose their contact pressure and this leads to bad connections here and there. Its always a good idea to replace those connectors to avoid display trouble in the future. The same applies to the CPU module with all its connectors. Bad connections here will lead to control problems and/or intermittent function.
You can see in the pic that I have fitted new Molex KK connectors all the way around module 8 and 9. I have also made a new cable harness with new connectors to module 9 instead of the old and often faulty flat cables.
The top pic shows the old display board.
The bottom pic shows the new display board together with the CPU module.
