I just finished replacing all the electrolytic caps in my BM1000.The amp is sounding excellent with my CDX but the FM was a bit flat sounding with very little stereo separation.In fact when switching the mono switch,I actually had to listen carefully to hear the difference.That is until I changed the last two caps shown in the diagram.I replaced the two tantalums with carefully matched 4.7uf electrolytics(measured 4.8uf).These two caps made more difference than any others in the entire amp.The stereo separation and soundstage through FM are excellent now.
The question I have is this:What is the technical function of the 2k trimmer called "noise suppression"?I have not seen this in other circuits.Was this used to balance the detector should the components drift over time out of the close tolerance reqiured in this circuit?If so,if I carefully match to within <1% with modern components,can I simply replace the pot,and the 1.5k resistor, with an exact matched pair of 1.5k resistors?Perhaps Metal film or carbon film?
Paul
