BeoVision 4 Rainbow Screen?!?!?
Hope this is the correct spot for this...
I have a BeoVision 4-50 (8950) that I was using as TV hooked up to a moto HD-DVR. Last night the screen goes all white and then rainbow colored. See attached image...
Anyone seen this before? Did I just blow up my TV? Is this an issue with the panel, a componant or something with the VGA input card?
I called the local B&O Dealer and they said I would need to have a tech come look at it, which I am SURE costs an arm and a leg.
Advice??
I see that this message in unanswered since several days so I will attempt to reply.
First, disconnect the TV from the mains and let it rest for a few minutes. This will reset the processors. Then, try to connect another source to the TV in the VGA input, such as a computer. Check also the set top box on another TV, as it may be defective.
You will be then able to discover the defective component, the box or the TV.
By the way, is your TV connected to a Beosystem (1,2 or 3) or you are using the Beovision 4 as a standalone TV ?
Good luck,
Jean
