Beotime clock movement
If anyone has a Beotime with a dead clock movement, the original Junghans ones can still be bought
My Beotime has a dead mechanism, but I think it may be a different model. It has Heichinger stamped on it, and I haven't been able to source a replacement. I wonder if the hands would mount to this one? I'll try to post a pic of it tomorrow, if anyone has any idea where to find one it would be fantastic.
Hi cozza, the fittings are standard Euro ones - ie;- the minute hand has an oblique/slotted hole.
Chris.
Perhaps it is the same one?
Yep - that's the same.
Chris.
Thanks - thats great! I look foward to getting the beotime back on the wall 😁
No prob's cozza - let me know if you have any problems with the shipping & I'll gladly send one (or more) on to you. The last time I spoke to the seller he seemed pretty laid back & amenable.
Chris.
Thank you Chris, that's a very kind offer. I'll contact the seller and see if he can post directly to NZ first.
