Hi have a BeoSound 9000 is the error in Servicemenu nr: 03 displays (radial error)
Does anyone know what parts need to be change.
Many greetings from Sweden
Jan
BeoSound 9000 does not play CD,s
I recommend that you change the cd mechanism. Talk with your dealer as there are various kits depending on the serial number of your 9000.
You will end up with the equivalent of a series III 9000 as far as the cd is concerned.
Thanks Graham, I have ordered the CD mechanism. It is a VAM1205 Philips
We will see how my BeoSound 9000 to operate after an exchange of the CD mechanism.
Greetings
Jan
Did you order the correct upgrade kit from your B&O dealer or did you just order a replacement mech on the internet??
HI Graham, i order upgrade kit PartNr:8420001 from B&O dealer.
Regards Jan
After replacing the CD laser upgrade kit Part No.: 8420001 my BeoSound 9000 works fine and without any problems.
Sincerely
Jan
Aah! So I am right sometimes despite what my wife says!!!!
Thanks for letting us know Jan
