I'm not out of the woods with this one yet. That's why I said I wasn't going to celebrate too much.
I tested it playing some music for a bit more last night and the receiver would randomly go into standby mode. So something is unstable...and probably in the power supply I think. Remember when I adjusted the 6.5v output I decided to adjust the trimmer to set the base of 16TR1 to 3.8V. That resulted in the output being 7.02V instead of 6.5V. The unit worked but later (and now) is unstable.
This morning I went in and decided to adjust the trimmer to back the output back to 6.5V. When I plugged the Beomaster in, it went right into the original fault state with only "P" on the display. Leaving it in that state I adjusted the trimmer to lower the 6.5V power supply output down from the 7.02V to 6.5V and the Beomaster clicked back into standby. Unfortunately, it now randomly clicks back to the fault state. So I believe I thave some unstable component in the path from the power supply module (16) through the motor control (06) and the microcomputer (02) ...still.
But that explains the original problem. When I first put the unit back together after the recap it would only go into the "P" mode. Had I known what I know how I would have looked at the 6.5V out of the power supply first. Instead I took out the 02 board, spent a bunch of time messing with the timing circuit (when it was probably perfectly fine). That also cost me the lamps for the volume control. Eventually I found my way to the power supply and resoldered the components (also checking them). That helped with the problem and I am now in the position where I am now - unstable power supply. I will go ahead and replace the trimmers I guess. The trimmer that adjusts the 6.5V output seems very steady though. As I said, when I checked the 6.5V output this morning it was still at the 7.02V where I left it. It also smoothly lowered the voltage as I turned the trimmer.
I also have the problem I observed where the frequency counter is unstable. I found out that those LS chips require a +5v power signal that is with 5%. I also know from the earlier testing that those chips were not on and keeping the Beomaster in "P" mode when the power supply voltage was too high. It would be good to determine what the source of this instability is.
