hi!
i bought a faulty bm6000 quite a while ago over ebay, and gave it a secod try now for bringing it back to life. it seems the microcomputer got stuck and doesn´t reset. so the reciever doesn´t go to stand by, but shows weired info on the display; after 2 or 3 seconds the amplifier protection circuit is activated and the display changes, but doesn´t go stand by.
until now i replaced all the capacitors, some of the transistors ( the ones involved in voltage-regulation) plus transistors, the variable resitor and the diode in the microcomputers reset circuit.
result so far: the powersupply delievers all the correct voltages, but the microcomputer wont reset and the poweramplifier still switches off the unit.
for the poweramplifier, i think, the problem could be the variable resistors for offset and no load current, but no matter, whats going on in the poweramp, the beomaster should go into stand by, when connected to the mains.
i tried to calibrate the ic reset circuit following the instructions in the service manual, but i failed to get the 2,6V over R90, but as i haven´t got an scope, it could be caused by my slow multimeter. depending on the position of the R89 i measured either 4,5V or 0,2V, but no values in beteween.
my guesses vary from the ic has left this world to i haven´t got the right equipment to calibrate the reset.
it´s a shame, as the 6000 is a relly nice machine and i´ve got already a beogram 6006 and a becord 8000 waiting for the right partner.
anyone any ideas?
any help very much appreciated!
have a nice evening
jens
