Beomaster 4500 mutes when programmed
I have the following setup:
Beomaster 4500 sw 2.1 two-way
4500 cd player
Beolink 7000
2 BeoLabCX100
Beovision 7-32, no speaker, linked to Beomaster 4500 via 1611
BM and BV in Option 1
Beo 4
2 LC 2
Link:
MCL: 2 BLCX100
Beolab 2000 via 1611
Problem: When I use my BL7000 to program my Beomaster to turn on the radio or 4500 cd-player at a given time it turns on, but the "mute"-function activates immideatly.
Why does my Beomaster 4500 mute automatically when programmed?
Do you have an idea?
Kind regards
Louise
Hello again!
Your timer is already programmed - but has not been activated!
- BM4500 has to be in standby mode
- touching "Programm" on BM shows "Timer"  (surprisingly in green letters!)
- touching "Timer" activates/disables an already programmed timer
If timer is activated "TIMER" (in red letters) is shown on the display of your BM 4500
Lieber Vienna
Thank you once again - that solved my problem. You are indeed a bottomless well of knowledge about my own contry's most famous AV-producers! I think Beoworld would experience a radical added value if you documentet all you knowledge and publicised it here. I am indeed very impressed, mein Herr!
Vielen Dank.
Kind Regards
Louise
