Beolink without eye in Bathroom
I would like to install in the bathroom a Beolink. I'm afraid of using the remote controll in the bath. I don't want that a remote controll of 200 Euro falls into my bath and get destroid. I know there are cheaper 3rd party remote controlls. But the problem will be the same only less money is getting destroid. I would like to ask if there is something (probably 3 party device) similar to the eye which allows you to controll the music. For instance to change the radio station of switch CD/radio? With the eye you only can change the volume and turn it on/off.
regards,
So what you want is the buttons to operate your system mounted on a wall? Easiest solution would be and eye and a 2nd hand Beolink 1000 in it's
