BeoLab Penta: Front Panel of the amplifier
Hello all,
I know this is a bit superficial, but one of my BeoLab Penta's front panels will not stay closed. Whenever I am playing music with a large amount of bass the door pops open.
Is there anyway that this latch can be replaced or modified – or should I just forget it and let it remain in the open position...
Regards,
Max
Is that the grey panel or speaker fret you're referring to? I presume it's the plastic panel... if so, you could simply use a little blue-tack! It's hardly a pristine repair but it should hold it...
Good luck,
 Alex.
Haha... I figured it would come to that. I am referring to the grey panel on the bottom – on the cover of the amp.
I think I might leave it as-is.
Max
