beolab 3000/5000 panel speaker amplifier
hi,
can anyone help me with a problem regarding the amplifier section of the above speakers?
the fault lies in pcb board 8001032 as i have exchanged this board out of another working speaker and it has rectified the fault.
the fault is that the relay does not click in when the speaker is sent a signal from the beomaster, no sound or display is shown, only the red standby pilot lamp is lit. there is a IC chip on board 8001032 ( IC 301)  i have replaced this with a new one, but it has made no difference.
can anyone help me locate circuit board 8001032, or help me locate the fault on it?
thanks,
lampy.
I suggest you contact Tim Jarman via
Hello, I've exactly the same problem you described. Have you resolve it and how ? Thanks. H.J.
You could ask Ipaul, member of this forum. He's a genius, repaired my Beolab 3000 amp.
