Hallo,
first I want to thanks all the people in the forum, who writes interesting tips regarding repair of the B&O stuff. I bought my first equipment one year ago (Beogram CD6500) and was able to repair it (servo capacitors) after researching in this forum 🙂
Now I own the second one, the Beogram CD5500. It had the same problems with finding the CD, so I fixed it exchanging the capacitors on the servo board. It reads the CDs without any problem. All service steps (1-4) are OK.
The problem is, that, if it is connected to my BM6500 I only can hear noise. All operations working fine (skip the track, pause, mute etc.) from remote or from the front panel. But no sound, noise only. Like from not adjusted radio.
Does anyone has an idea ? Thanks in advance !
One tip from me: the Beogram CD5500 player had problem with the CD tray. After some close and open operations it was slower and slower and finally it stoped the moving. I found out, that the soldering of power supply cables on the main board was broken. After new soldering the CD tray motor seems to have enough power to work properly (or the microprocessor, I don't know).
Regards
satmonster321
