Hi Clive,
Thanks for the pics - that's a new one on me. The ones I've had in, in the past, have all been with regular TTH (Through-the-Hole) capacitors. I've not seen one yet with the SMD's. In general, SMD caps are far more failure-prone than regular TTH capacitors.
IIRC, it's got something to do with the extremely high temperatures when doing "reflow soldering" during production, something which was never done in the old days....
I learnt that through hard experience on my Tek oscilloscope - Tek used SMD's on one of the PCB's, and they leaked their corrosive electrolyte all over the fine traces - what a disaster. The other PCB's with TTH caps are still going strong.
When replacing the SMD caps, replace them with regular TTH caps, just soldered onto the SMD bases - the machine will have a longer trouble-free lifetime.
Menahem
