My tonearm now lowers to the record and returns at the end of the record with no fault. I was in contact with Dillen who helped diagnose a few issues and non-issues. He told me it was most likely the oxidation on the contacts wearing off or loosened up grease after me trying the tonearm so many times. I was also able to put the tracking weight on point at 1.2g instead of the 1.5g I thought it was for the BC7700. I am going to try to clean up a bit (check that pin) since it has been sitting for the last 30 years or so.
As for the lights, I learned that the large red LED display are its own separate component that would need to be worked on, which I understand is a very detailed process. But if I were able to just find another working display of another BC7700 then, that I could swap them for a smoother process. So far, I am fine with a few lines missing from the display as I can make them out for use. Eventually when I find this beocenter for parts, I will try fixing the display.
I'm going over the service manual, to see how to fix the control panel door. I see that there is a black latch (friction plate, #2038) at the rear of the door that seems to be cracked. I am able to push the whole door down with much force feeling like something else would break, then it rises back to open about 20%. I'm not sure if it's normal, but the control panel door lifts up more than the record player dust cover.
It make sense that there is another latch at the front to keep it shut. From the service manual, I see it could be #2041, which is a lock it says. It is not an issue that keeps the unit from working, only visual and I can make sure to take extra of cleaning for dust. I'll keep trying with this one.
My tape deck doesn't seem to work, when I start it, I see and hear a large click of the metal mechanism. The metal part seems to grasps the tape but then retracts from it. I doubt that I am going to use it as much as I will the record player so probably a later project along with the display.
This forum has been a big help to me already and very welcoming. Hope you all enjoyed a great Christmas.
