Hello
I'm working on a project cover to solve the problem in a broken hinge, it seems to work... I'll let you know if this fix the problem!
Hello
Thanks Eugenio
Cant wait to see the fix, there are alot of aging dust covers out there which need this work!
Andrew
It seems to work.... 😜
Ciao!
Could you shed a little light of how you did it?
I've a BG2000 which have higes broken and looking for a fix.
Regards, Pekka
Hi!
The white pieces are made from the original, I used a mix of plastic resins and then adapted to fix in the cover.
To create this parts you need a vacuum box and a little furnace (temperature controlled), so if you need I can make for you the hinges; you pay only the delivery tax and little price for the materials, I don't want ANYTHING for the work because it's not my job (it is an hobby for my mind and a game for my son in the avatar ).
As usual, if you find someone that make this as a job ask him first! :)
The difficult is to find the proper resins mix to have the needed strenght.
Actually I'm working on to solve the problem to let the cover opened whitout stressing the hinges; next on this topic!
If you need you can contact me on msn
mastro_vintage@hotmail.it
I'll be very happy to help you
ciao ciao
Eugenio
Hello
I definitely solved the lock of the cover in open positition, no hinges stress, no dents reinforcement, no bigger spring! As soon as is possible I'll upload photos.
I'm very very happy to share with you.
Ciao ciao
The work is not clean, it's a test.
The result is very good, the cover remains in open position, even if the alu plate is in vertical position or rotate to the front of the unit.
First I tried to create a strong and flexible dents as in the following image (sorry for the dimensions)
But this solution (even if works from about 2 years) is not easy to realize, not so beautiful to see (even if painted black) and stress the hinges; none cover hinges broken right now but the pressure on them is very hight.
So now there is the definitive solution 4 little pieces of...
Lets the game start!!!!
