hey, i got this defect tv for free, they told me sound module is defect, and cost 5-6000 dkr to repair. i did not get remote control, and i don't know if i can turn it on witout remote control?
beo vision 3-32 defect or? No, just need remote and pin to turn it on
I don't know where you live -but I guess that you can buy a fully functional BV 3 cheaper than spending that amount of money on a repair.
Here in Denmark these Beovision 3's are sold as cheap as 1000-1500 DKKr (200-300$).
I live in denmark, i got this free because the repair priese, but still, there is light in the standby led, it can be turned on with remote (i don't have any) and hope i can turn it on witout remote until i know i i can repair the sound module.
Do you know if there are any way to turn on power witout remote control?
thanks ;)
As far as I know, no, there isn't... most modern age Beovisions are useless without a remote.
More importantly, without a remote you can't enter the PIN code (hope you got one!) and the TV wouldn't work anyway.
okay, thanks, no i dit not get any pin, but just send them a mail and hope they remember this pin.
This code must be stored inside a eeprom, so might be possible to 'snif' out data with a arduino he he ;)
But hope they will search for the PIN code, but i got it for free so i don't know if they will spend time on this
Found this link
I got the PIN ;)
Also got the name of shop where they bought it from new in 2006!!!
Very expensive television, 30000/5 = 6000 Danish kr each year. Or am i wrong? did they sell some ceaper versions?
I wouldn't get too excited about the price when new - here in the UK you cannot give these TV's away.
Unless you REALLY want it then spending any amount of time or money on it will be a pretty worthless excercise. This sounds a little negative but is only a true reflection of the current trend for flat panel TV's. I had an Avant which shares the same basic chassis of the BV3 & I absolutely loved it but when it eventually decide to stop starting up I simply threw it a way as it wasn't worth me spending any money on it. The BIG problem with these TV's is that the tube will soon fail & that is a very expensive problem to put right.
Chris.
'here in the UK you cannot give these TV's away' Why can't you give them away, are there some kind of protection?
Well i agree not spend lot of time (and zero money) on this teli. I am aware of the problem with avant tube, but hoped they fixed that in these new'er beo vision 3. Well today i use samsung hd lcd tv, but back in 1992 i got a b&o lx2802n, great television, great sound, simply the best picture on the marked. So if i can get this beo vision 3 up runing it would be great and always better pictures on tubes, i think, or maybee the best to do is to find someone that needs a tube ;)
I guess what he means is, that nobody wants them anymore...😕
I also used to think so - and it was true earlier. But I would say that a plasma gives you a picture wery much like a CRT(tube). Just better, because of the higher resolution. In my opinion the LCD (or LED) are not good enough yet -or maybe they'll never be...The picture is not as "natural" as a plasma (or CRT).
When i sold my BV3 and bought a flatscreen, there was no doubt in my mind: Plasma.
