henrykin wrote:
What I did was to use the technics as pre amp by jack plug from technics to 5 pin din
into BM 7000 aux B&O said to use this port. Set both vols to 0
I increase vol on 7000 TO 12 and then incresed the vol slowly on the technics
and the vol increased nicely on my 7000 to sound like the vol of my 5500.
Here's the e-mail I recieved
We are pleased to see that you are the owner of Beomaster 7000. You can connect a pre-amplifier to the Audio AUX connection. However we are not able to recommend a model.
Kind regards
Bang & Olufsen a/s
Mette Krabbe Helmholt
BeoCare
and no fireworks.
Now waiting for a preamp from the US
Aha, mystery solved!
Yes, this is the correct way to connect them - all that talk of 500W output had me confused, as of course the preamp output of a 500W amp is the same as the preamp output of a 1W amp....
Other than some more inputs (probably including digital) what have you gained by using the Technics? The signal still goes through the Beomaster 7000's preamp, so I'm not sure what you've achieved... 😮
Have you got any speakers attached to the Technics, or are you just using it as a preamp? Some amps don't usually like playing into no load at all, it confuses them...
Plus this brings me on to one of the things that always annoyed me about the Beomasters that take passive and active speakers: when connected to actives, that poweramp is still working, which is a waste of energy really...
