Hi Everyone
The latest update on the quad has both good news and bad news. First the good news.
After fixing the control panel, I reassembled the unit to give it a serious test run. The first problem I encountered was related to the improved key sensitivity because after the panel was pressed into position, program P1 was permanently engaged. Removing one of the shims under the P1 key quickly fixed that.
The control panel was now a pleasure to use – it was very sensitive and getting close to the touch panels on the BM2400. What a difference from the earlier setup. I settled down to listen to some music on the radio and connected a tape for better quality. My first impressions were that the sound quality was very good – I have heard it described as a “full” sound and I liked it. On many other machines, I tend to use the loudness function to get a fuller sound but this wasn’t necessary on the quad. As I said earlier, I was very impressed and from an operating perspective I can now give it very high marks. 🤒
So what is the bad news? Well, if you can remember, my two outstanding problem areas were the switch on “thud” and general box cosmetics. It is the “thud” that I simply haven’t been able to find a solution to. I have tested lots of things and tried a number of fixes but so far, the solution eludes me. So, what have I done to date?
All of the electrolytics on the main amplifier have all been changed.
All 20 tantalums on the tone board have been replaced. This actually changed the sound of the thud from the horrible rasping sound of a lightning bolt to a lower volume “boom”. I was grateful for that improvement because the former noise made my hair stand on end.
I found a faulty transistor 2TR8 on the 20V supply and replaced the BC143 with an NTE129. This fixed the local voltages but didn’t help my thud.
Martin mentioned that there might be a problem with some parts of the ground wiring and I did loose a connection on one occasion. The earthing is now good but it hasn’t improved anything.
I lost 12IC1 which was the volume controller and replaced the MPSA65 with a BC516. The volume control is now good but I was starting to wonder if the “thud” was now blowing up some of the components. That was a worry because I always needed to hear the thud to check if it had been fixed or not.
On one occasion when the amplifier board had been lifted and the tone board was in its service position, I switched on to find that there was no thud. With a smile on my face, I replaced the boards only to find that it had returned. I was never able to reproduce that condition and wondered whether there were loose joints or tracks around. That was going to be an awful job to undertake and I never started it.
I did extensive tests on the power characteristics and was generally happy with the power supply. However, I did decide to replace the 3000uF cap on the 18V supply. That change didn’t alter anything and the original cap must still be good after all these years. To date I haven’t swapped the 10000uF cap but the 60V supply seems to look pretty good. I did replace the small 47uF cap which filters part of the 60V supply but still no joy.
So there we have it – I am now the owner of an acoustically disadvantaged quad. I will leave the cosmetic repairs until a much later date because I know that this machine will be taken apart again sometime. I would have loved to end this saga on a note of perfection but that is not meant to be. This project is now in the “too hard” basket but at least I was able to obtain a good sounding, nice working unit and it has all been good, hard, honest fun.
Thanks for all of your support. It has been great to read your comments and I think that we have all learned a lot. Now to find my next project - hopefully easier than this one ???? 🙂
Regards
Geoff
