Hi Everyone
As I mentioned yesterday, this project is nearing completion. The Beomaster 6000 quad has now been re-assembled and will be put to one side while I catch up on all the other tasks that I have ignored over the last few weeks. So what are my latest conclusions about the “quad”?
Well, I have taken an old unit that wasn’t even making a noise and returned it to a condition where all four channels are producing a good sound. For me, that was the primary objective of all this work and I have achieved what I set out to do. Very satisfying for a rank amateur.
I have learnt that this Beomaster is extremely complex and difficult to work on. While trying to cram everything inside that tight box, I was always concerned about possible short circuits. Every time that I switched it on, I was expecting a flash of some sort. It will actually be a welcome relief to work on something easier for a change and see my pulse rate slow down.
It has been slow and painstaking work and I can understand why Martin inferred that there wouldn’t be too many people who would be prepared to undertake this assignment. The man hours are going to be very high and at times, progress is very slow indeed. I’d hate to be paying for it by the hour!
I have always liked the appearance and design of this Beomaster when I have seen it in the sales brochures and magazines. However, in reality, those horrible wear patterns on the push panels and the aging marks on the black display panel do make it less attractive when you look at it closely. Recovering that wonderful, original pristine condition would be a mission impossible for me.
My first impressions on the sound quality was that I was happy with it. One day, I will set it up properly for ambiophonic reproduction and give it a good test but in the meantime, it still sounds good on my “low fidelity” work bench. I don’t think that I will ever be able to get a quad source to evaluate - but one never knows.
The first pass on this Beomaster has fixed a number of issues but there still remains more work to be done. So far, I have come up with the following list. Most of these tasks are fairly simple but there are some that I would appreciate more help with. Here they are:-
The “power on thud” must be fixed and I am still not certain which components I am going to have to replace. This is probably the area that I least understand and require most help. I plan to investigate it more thoroughly next time the machine is open.
The front / rear balance indication is not working but I do hear the motor turning. This probably means that there is a wiring loom jammed on top of the drive wheel. Should be very simple to sort this one out – after all it was working when the cover was off.
The tuning indicator is very far out, probably about 50mm from the correct position. I am not sure how it got in this situation but it is normally fairly easy to reposition the clip on the string.
Some of the push panels are not acting as good switches. I hope that it will be possible to improve the sensitivity of these, after all, only a delicate touch should be needed, not a high pressure thumb print!! Has anyone tried to address this problem on these push panels or any other similar machine that uses them?
P5 tuner is definitely broken but I wasn’t able to get any access to the trimpot. My first impression was that it was a sealed unit but I could be wrong. Can anyone advise me how to successfully dismantle this assembly, there are no clues at all in the service manual.
There are several pinholes in the black mask on the display panel which let light through and detract from the appearance. A touch of black paint on the underside should fix that up fairly easily.
The cabinet requires a lot more TLC to bring it back to a superb condition. This is just fiddly, time consuming work that can be done at any time – but in the end, it will be well worth it.
Well that is my short list, not much is it! This Beomaster is almost back to being a useful piece of audio equipment. Here it is ready to go into hibernation for a while.
My thanks go to all Beoworlders who have been supportive of this project. I hope that you found it interesting and one day perhaps, this thread might be of use to someone else who is also working on the “quad”.
Best regards
Geoff
