Will BOTH BeoGram 6500 and BeoSound 3000 connect to either BeoLink Passive OR
OR BeoMaster 7000? The BeoGram can be operated manually but does it have to be connected to a receiver to be heard through speakers?
Hi and welcome to Beoworld!
I am slightly confused by what you want to achieve! The Passive does not work as a stand-alone amplifier (without a powerlink input trigger) so at the very least you will need the Beogram to be connected to a Beomaster/Beosound first, not least to control volume. Then you could connect the Beomaster/Beosound output to a Passive via Powerlink.
You could simply connect the Beogram to the BS3000 aux input, and then connect the BS3000 powerlink output to a Passive.
Alternatively, you could connect your Beogram to the AAL input of a BeoLink Converter Type 1611, then masterlink that to a Passive input. If you then connect an IR eye to the Passive you will be able to switch on/off and control volume by selecting a Video input with a remote. You will not be able to remote control the Beogram, so that will be manual-only.
