hello?
this is my first post, first asking
I have a no idea.... which one's good for beosystem 1
BS1 is 480i and 1080i... is it?
I think... I don't need full HD tv
What's BS1 Display Refresh Rate?
Please.. help me
many regards ;)
kevin
hello?
Please.. help me
many regards ;)
kevin
how about...
Spheros 42HD 1024 x 1024 pixels
| Broadcast Format Displayed: | 720p (HDTV) · 480p (EDTV) · 480i (SDTV) |
| Broadcast Format Supported: | 1080i (HDTV) · 720p (HDTV) |
VS
Beovision 5 (type NO 8901) Pixels 408,960 (852 x 480)
regards
The Loewe Spheros 42HD is a decent TV. I bought one for the living room a few years ago, just before they left the US market. Picture is excellent on HD, kind of blurry on SD (not as good as the old Panasonic tube). Sound quality surprisingly is very poor - boomy muddy bass, tinny highs (BV8-32 is much better). However the motorized floor stand gives it a B&O flavor 😁. I remember thinking, looking at the specs, what a strange resolution it had!
Leo
thanks! leo
so do you think that Loewe Spheros 42HD is work with bs1 ?
or can you any other model(non B&O) recommend it.
what B&O tv is perfect for BS1? which model, type, SW
regards
kinban
I am using a Panasonic TH-50PH9UK 50" Plasma with my Beosystem 1. I believe it is the same base panel that is used for the Beovision 4, but at a fraction of the cost. It's a great panel, and works well with the BS1.
thanks
now I'm more confuse
Panasonic TH-50PH9UK was good... in 2006
how about
now I understand what you saying
I just got a beosystem 1, It doesn't work...
I don't know.. I don't have IR revciver,
and I use computer cable(rgb to rgb) to my son's tv(17")
but beosystem 1 makes "cliking"sound when I putsh TV button on the beo4...
no signal on small , disney, toystore, my son's LCD tv ....I use for test..... I don't have TV yet
Do I need a BV4 for test
and maybe pal signal set up on system 1 then still can see noise...... right?
..... dummy design, no power button, no indicate light on (hard to tell power on or not)......... unusual cable position..
I belive that sound is good... I know that my bl2000, 2500, 4000, 6000, 8000...... they are good
help me ... Need a surroud heaven
