How do I connect an Apple Airport to a Beolab-2000?
A customer of mine has a Beolab-2000 and asked me if we can fix his problem: he wants to connect his Apple Airport to it. He only has the Beolab-2000 as Bang&Olufsen, the other equipment is all Primare which we installed in his house together with a 60" Pioneer Kuro!
I already know what the cable-layout of the Masterlink is, we disconnected the plug of the Masterlink cable and tried to connect a cd-player with a stereopair of RCA's, but that didn't work...It also seems the Beolab-2000 isn't fully on: there is only a red LED and I guess it is still in standby, right? Pushing all the buttons wil not result in a green LED.
Do you guys have any tips? Is there some kind of trigger necassary to get it out of standby or what?
Thx Paul.
http://www.beoworld.org/beotech/wiring4.htm
For normal B&O speaker I think it would be way easier but since the BL2000 is designed to get the source from the remote B&O system it will be tricky.
jk1002:
You mean impossible?
I would not say it's impossible. After all you have the basic elements for what you are looking for. Having said this, I think without some advanced knowledge of how the BL 2000 and ML work, it will be extremely difficult.
Let us know how you fare.
The central issue issue here is that the BeoLab 2000 was intended as a dedicated/dumb/downstream terminal meant for use on a propietary network protocol, not as a stand alone speaker.
You are in essence asking: "I've gotten my hands on a Diebold ATM machine from my local bank.  What do I need to hook up a hard drive so that I can watch video on it?"  The answer is that it may be possible, but there isn't some magic cable that is going to do it for you.
Trip
Sell the client a BS4000; connect the AirPort to AUX in and run it that way; else, take the BL2000 in on trade and find a better fit...
