Connecting BeoLab 8000
Excellent!  I appreciate the help.  Thanks.
I've read this thread and it almost answers my question.  I am trying to do the same thing.  I have a Fujitsu TV with positive/negative speaker outputs for both left and right speakers.  How do I connect these to my two BeoLab 8000 Line In connections?
If the jacks on the terminals are meant for regular stranded speaker wire, it will not work directly.
Does the Tv have pre-amplifier outputs? If so, those are what you should connect your BeoLabs to.
If that is not the case (no pre-outs), then you will need to source some attenuating cables that will bring the amplified level from the tv down to line level.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
Thanks for the reply.  I studied it enough that I was confortable with conncting one of the speakers to the TV output.  It worked fine.  The volume control on the TV controlled the volume of the speakers very well.  My only problem now is that when the TV is turned off, there seems to be enough of a signal or feedback such that the speakers do not realize they should turn off after the 30 seconds to a minute that they wait.
I took a very cheap RCA cable and cut off one end to expose the bare positive and negative wires.  I'm willing to use better wires for the permanent solution.  Any suggestions on how to eliminate the noise when the TV is off so the speakers turn off?
The speakers don't turn off instantly in the absence of signal . They stay on for up to 3 minutes . The maximum I have observed and eventually turn off. Once a signal is re-applied they do turn on.
There are various solution to eliminate this completely but they are more involved/complex.
Lesly
Use shielded cables where the negative (ground) wire is the shield, I had the same problem and the speakers never turned of, and gave a humming noice, when I turned of my amp. When the amp is on and there is no sound to the speakers, there is no noice, and they turn on and of like they are supposed to, so something  is happening when the amp (TV) is turned of.
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
In many Kikinoko flat TVs, the audio amps have been implemented with some IC probably selected mainly for power efficiency and work in class D or S (technically a bit like ICEpower, only crappier 😂 ). Depending on the output circuitry, they may show a high impedance when powered off, and the cables connected to your Beolabs start to work like antennas, collecting all kind of noise and power line hum. That might be enough to make them think they are being fed with a signal, and stay on.
I would try adding a resistor to emulate a speaker load at the TV end of the cabling, so they aren't left dangling in thin air so to speak when the TV is powered off and essentially disconnected from them.
But I still wonder about the signal levels, if you are indeed connecting to outputs that are supposed to drive passive speakers. Theoretically it should be too much for the Beolabs.
