The light on my BeoVision Avant is blinking when the system is in standby. Everything seems to function fine otherwise. I've put the system through its paces and cannot find anything else out of the ordinary.
Any ideas?
Any ideas?
It happened to me sometimes, I used to simply set the video option again with the Beo4. I don't know if it is a standalone set or if it's linked to an audio system but you can just try to do the following :
Stand in front of the TV so that the remote reaches the avant :
Press the STOP (red dot) button in the beo4 ****simultaneously*** with the button list,
Press LIST again until you reach 'OPTION?'
Press GO
Press LIST button until you reach 'V. OPT' flashing
Press 0 if it's a standalone TV
Press 2 if it's linked in the same room to an audio system
Press 1 otherwise.
You may also try to simply plug/unplug the power (i guess you've already done so...)
Hope this help.
Thanks Moolauss. I'll give this another try. Even if it works, you can imagine my level of comfort with "unexplained" blinking! 😕
Thanks again!
