i have a pair of bang and olufsen RL 140s and on the back plate that is metal has 4 screw holes that are empty i dont know what they are for i want to wall mount them but cant find wall mounts for them, im wondering if i used a flat panel tv mount can i use these screw hole to attach them to it or are the used for something else that might not support the weight does anyone know what they are for and if they can be used for this any info will be great thankyou in advance.
Taylor T
