That's bad luck. Not sure why one of the units buzzes he should be able to say why.. I would suggest the coil former is not aligned or miss-shapen.
Anyway you need some identical replacments you might want to keep an eye on ebay etc.. put a wanted here and talk to Dillen (Martin).
Just out of interest get the old ones back and take some pictures. I would not consider it impossible to rewind the coil and I am sure the 'buzzing' could be tracked down and rectified...
