If you decide to take the dome mids apart, it's a pretty easy and self-evident thing. There's 3 plastic tabs that click into place behind the metal rim of the driver frame. They're attached to the diaphragm/voice coil assembly. Just pop back those three tabs and the whole diaphragm/voice coil assembly lifts right off.
There's a small difference in sound between the earlier, clear domes, and the later, fabric domes. With the given crossover network in the MS150, the later, fabric domes sound ever-so-slightly more laid-back and pleasing. The difference is slight, and I mean slight. If you can find a good set of those, they'll work too, IMO. Won't be original, but it won't be way off either.
Jon
