Hey Daniel, a couple of things here.
To me, 60wpc won't be enough.
Audio manufacturers like to be sneaky and say "high-current design" making people think that it's better than a "regular" (???) amplifier design or something.
However, the Beovox MS150's are an 8 ohm nominal speaker. So, you can have a super special "high-current" design all you want, but the amp in question is only going to be able to deliver so much current into the speaker for it's given impedance.
Say you've got two amps, one a quality "regular" amp, and another, "high-current" design, both similar enough in design and layout to be fairly comparable, and both rated to deliver 40 V at the power supply rails. With the MS150's being "8 ohms" (which is a bit of a misnomer, and relates to the whole damping factor thing, which I'll get into in a minute), you're only going to be able to deliver 5 amps max into them (mathematically anyway, not counting losses and inefficiencies, and impedance irregularites), regardless of whether it's a "high-current" design or not. So all that "extra current" goes to waste!😂
No, but, do you see what I mean? Power is voltage times current, and current is voltage divided by resistance. Unless you're looking at wiring up three or four sets of MS150's in parallel, a "high-current" design (one that actually delivers on it's promises, at that) pretty much means nothing.
About the impedance and damping factor thing... Damping factor is simply a numerical value describing the load impedance divided by the amp's output impedance.
An "8 ohm" speaker like the MS150 or almost any speaker on the the planet isn't really a linear 8 ohm impedance. If it were, it would be a resistor. That's why speaker loads are described by impedance, which is basically a reactive resistive load. A speaker's impedance varies with things like frequency, enclosure tuning, voice coil heating, and non-linearities in the motor. It fluctuates just with the movement of the coil in and out of the magnetic gap. It presents the amplifier with a load possessing inductive and capacitive properties.
Even with a decently linear speaker like the MS150, which has impedance compensation networks in it's crossover, it will have a relatively large "double camel hump" in it's impedance graph around it's enclosure tuning frequency. Look at this chart I pulled off the Stereophile's website of a JBL speaker (first one that came up in a Google search):
See how the dark solid line varies between about 3.75 ohms and over 20 above and below the port tuning frequency?
Given Ohm's law, you'd think the amplifier's frequency response would mirror that of the speaker's impedance, and in crappy amplifier designs, it does! But a low output impedance (i.e. high damping factor) means that the amplifier is more of a constant voltage source, not letting the speaker's impedance affect it's frequency response.
And of course, the speaker itself will have a voltage sensitivity that looks a bit like it's impedance plot. This is why you can have a very irregular impedance, and still have a flat response (I don't know if this JBL has a flat response, I'm just saying it's possible in a design). Basically, there's less current delivered to it at certain frequencies, but the frequency response of the speaker doesn't dip because of the higher voltage sensitivity at that frequency.
Combined with an amp having a high damping factor, the final result can be very flat response, despite the impedance being all over the place!
By the way, I'm working on packing your 8" drivers. Hope you find it satisfactory.
Regards!😁
Jon
