Beovision 7-55 speakers
I need some direction on adding or should I state getting my Beolab 4000's to work with the 7-55. I have them hooked and set up and ran the set mode.  However, they don't turn on when the TV is turned on. If I go into Options and select Adjustment and highlight video speakers 2 or 3 the speakers turn on and sound great. When I select store the speakers go into standby. How can I get these things to turn on when I turn the TV on?
Any help is appreciated.
You use the BL4000 as rear speakers I assume.
1, select left/right speaker on rear side of your BL4000 (not line!)
2, you have used the rear speaker output sockets of BeoSystem 3 of your BV7-55
3, you select BL4000 in the DSS setup of your BV7-55
select speaker modes 1-5:
Mode 1: Stereo centre speakers (subwoofer muted)
Mode 2: Stereo in L/R speakers (subwoofer is active)
Mode 3: Dolby 3 stereo
Mode 4: Dual stereo, stereo in L/R front and rear speakers (subwoofer is active)
Mode 5: Dolby digital, Dolby Pro-logic, DTS, Dolby 7.1
That`s it!
Thank you very much for your help.
I have the 4000 as rear in my 7-55 setup with BL9 as front.
I think that the 4000 are brilliant speakers.
