A Beolink 1000 will definitely work with no problems whatsoever.
Ron - check if your remote is working at all. Take a digital camera or a camera phone (with live view) and point it at the transmitter end of the remote when you press buttons. You should see the LEDs flashing pale blue if the remote is working.
If it does, you either have a fault in your Beomaster, or if you just got it and never have seen it working with your remote, it may be programmed to the wrong option (IR receiver off). With the Beomaster in standby, press SOUND - 1 - STORE on the remote. If the standby LED blinks while doing this, there's a good chance you now have a workable combination 🙂
Even the oldest Beolinks maintain their value surprisingly well, the going price can easily be around 40-60 dollars / euros / pounds for a nice clean specimen. You can only find bargains if the seller doesn't know what he's selling - or if the deal includes an old television you need to carry away!
And Jason, you have a system that is easily worth $1000 or more in working condition. Don't be cheap on the remote! Those plastic things are horrible!
