Well, I've moved halfway across Canada, but the system is finally up and (mostly) working, although I've been wavering about whether to get that belt repaired or not. I'll probably end up doing it, but right now it's pretty much a non-issue; where would I even be able to get tape cassettes at anyway?! 😁
I do have a couple questions about the system. Like I said, everything seems to be working fine, except with one exception: the Beomaster 5000 has a few buttons that don't seem to work! I never noticed it this summer because I mostly used the MCP, to be honest. First off, the outside Mute and Play buttons don't seem to work – they don't have that satisfying "click" feeling that the Play button on the CD50 does, either. So, in order to turn off the amp, I usually press and hold the Play button on the CD player, which turns off both, or I let the CD player run its course and shut down, and eventually the amp goes to "sleep."
The other buttons that don't work are on the inside panel, and they're the right-side row of buttons running from "FM Mono" to "Advance." Oddly enough, the single button at the end, "Store," does seem to work – at least when I push it, it gives me the P sign. The others just have no response.
Anyone got an opinion? I'm not terribly concerned because I just use the MCP most of those functions anyway. Still, I wouldn't mind knowing if it's symptomatic of a larger concern!
Finally, the speakers I ended up picking up were Energy's Pro Series 4.5. They're about 7 years old, but from what I understand were made when Energy still had that small-company quality, and as far as I can tell they sound simply fantastic. The question I had was about how much I should be careful about driving them with this amp. They're not "big" speakers – 15-150 W RMS – but that's probably still a little bigger than what this amp was meant for! Thus, I'm curious as to whether anyone has some recommendations on how loud I should be setting my amp. I did some testing, and things sound pretty gorgeous and very clear up to the 3.4 (out of 6 of course) range. But, I stuck some Tool in for some dense, heavy sound, and slowly cranked it a couple notches to see what would happen. At 3.8, I suddenly got some small crackling, so I turned it back down pretty quick! Since then I've been a little paranoid – I'm not sure if it was a product of the speaker, amp, or the shitty speaker wire I'm currently running them on (although it is very short, about 5 feet or so, so that shouldn't be an issue.)
Any of that sound suspicious to anyone?
greg
