Alright, so, I found those suspension screws on the bottom and yes they were tightened down...so I loosened them off, but it didn't make a difference. Then I made the connection with those three screws underneath the platter (and that back piece), and tightened those down pretty much all the way, and of course the platter lifted itself up and started working smoothly. I still have to fiddle around with getting it even, but would anyone have any advice as to how tight these top platter screws should be? Should they be tightened down with the platter raised the maximum amount, or just the minimum amount to let the platter glide smoothly?
As I'm a poor, broke-ass law student, I just don't have the money to get a membership unfortunately...getting those Beocord belts and a cartridge is taking care of that! Good thing our dollar is doing so well against the US' right now, haha.
My other question was about speakers. It was mentioned before that any speakers will work, but from making offhand glances at the Beomaster it seems to me there's some sort of proprietary connection going on for inputs, is that correct? Is there a generally accepted best way to get around that? I'm getting excited about getting some speakers, but this thing looks so sleek sitting Beocord-Beomaster-Beogram CD with the Beogram right on top in the middle...I'm gonna need fancy speakers to match, damn!
Thanks again for all the help! 😁
greg
