Hello, I recently ran into a Beosystem 5000 from a family member. It's in great cosmetic condition, but I can't get the Beogram and Beocord to work. I was wondering if anyone might have any advice for me.
First off, the Beogram 5005 doesn't have a cartridge. I understand that's a huge expense, which sucks, but what I was even more worried about was that it just plain doesn't work. π Okay, I'll explain: when I got it, the metal plate wasn't really inserted properly. I snapped it in, and it seemed to "fit" okay and snugly, but when I turn it on, the plate makes a scraping sound, the turntable kinda winds down and then shuts off. When I take it off, the black plate and electronics underneath seem to move okay. So, I thought it was more of a problem with the way I was fitting the plate on top, but nothing I do makes any difference. You can even sorta see on the bottom where the plastic has sorta been scratched from where the plate has been scraping around on it. I don't want to fool around with it too much and maybe damage it more, especially if I'm doing something wrong. Anyone got any advice??
The other issue is the Beocord. It opens up, but none of the buttons work. There's a tape in the machine, but anything I push just gives a clicking sound. When I switch to it on the Control Panel, the right side just displays zeros (000 etc) and nothing works there either.
What do you guys think? The CD50 and receiver seem to be quite fine and sound nice, but I'm not sure if tampering with the others is really worth it. I went to a B & O store and they were absolutely no help at all, other than to say "well good luck sucka, haha!"
greg
