Beosystem 1 and HD Cable Box
Are you getting sound and picture,b ut no control, sound but no picture, or actual nothing?
Russ
I get sound and picture and I am able to open up the menu for the motorola box (using beo4) but the buttons do not control anything.
Make sure flasher is pointing at motorola box IR sensor correctly, looks like you have everything else set properly.
I tried every place but got nothing. the only thing that worked was the menu on the beo4 that showed what buttons controlled what on the dvr. I guess I have to use the motorola remote. Thanks for all of your help.
I would not give up just yet :) using Beo4 is essential (IMO)
1. Double check that IR flasher is working and connected to STB CTRL input.
2. Make sure you are using STB input when assigning device (motorola box)
and also try selecting different motorola HD box if available devices, just to see what happens (you may get different buttons controlled on screen)
I checked the version of the software for my BS1 and it has 4.7i
I double checked the IR flasher and it was connected and pointed at the motorola sensor and I tried all Motorola HD boxes but only could bring up the menu.
