I've noticed that recordings made almost 30 years ago appear to have self erased, none are as loud as they once were and high frequencies seem to have attenuated. For the most part, if I can reuse the old tapes this isn't an issue, except for one thing, the azimuth aligning tape appears to be completely blank, at least I'm not seeing anything on the VU meters or hearing enough to confidently adjust the azimuth and know I’m not doing more harm than good. Any ideas on how I might be able to recreate or replace this tape?
Additionally, I uploaded a video link so you can see what prompted me to want to check the azimuth. If I record one side of a tape the playback sounds perfect, but when I record both sides of the same tape I get crosstalk. Could it be that every one of my old tapes are no good or might it be an issue with the Beocord’s circuitry?
FYI: The tape I used for the video is a TDK MA-R90, probably the best tape I have, but every tape I've tried so far is doing the same thing. Regardless, I would like to have a working azimuth aligning tape, preferably the original one that came with the deck.
[Video]
