BEOCORD 5000/5500
Hello, I have a Beocord 5000 that won't turn on. R.fuse on the power board ? - I also have a Beocord 5500 that don't want to rew or ff . It starts to play, and stops after 2-3 sec.Tray motor turns on too. When I push play, it plays and turns - (logic issue - IC 1 ? )
R. Lasse - Norwegian newbie here.  Hope for some help  :-)
Hi Lanola,
sounds like you need to fit new belts.
see Beoparts shop !
good luck
ALF
were can I find the Beoparts shop ?
Ken
you find them here: https://www.beoparts-shop.com/
