BeoCom 6000 Replacement Batteries
Hi, any recommendation to buy replacement batteries for the BeoCom 6000 system handsets. I orderd some from batterydepot.com but the system doesnt recharge them. I did enter the activation code required but that didnt help either. Either I dont have ctivation code right or there is some compatibility issue.
Any suggestions on either how to get these batteries to work or  place from where I can get batteries that are compatible with the system. I really want to try and avoid paying $50  per battery to the B&O store.
I vaguely remember something about this where someone found a really good source for them... 🤔
Anyone?
Oh, and welcome to BeoWorld !!
Lee
USA? I have purchased from
Wow I wouldn't think that parts for such a proprietary brand like Bang & Olufsen could be found in radioshack.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
Well, they are just batteries...
True but batteries can be quite specific nowadays. Especially in the rechargable segment.
B&O stores sell them for $27.84...
Thanks for the warm welcome and suggestions.
@Burantek: Are these the batteries you get from RadioShack. The customer reviews for these are pretty bad which is wehy I strayed away from them. Otherwise the convinience fo going down to a local store and getting something is great.
link
Is the activation code you use after you put them in : 9#9#9*655 ?
@ : Which B&O store. I called the store in Portland which is the nearest one to me and I was quoted $50 + shipping for each. Thanks.
Thanks all for your help.
Well if the batteries being sold by the B&O store are getting better feedback than the radioshack batteries, then I would probably go with the B&O batteries because they are apparently more feasible than everyone previously thought.
Oh, and welcome MurphyBrooks. I hope you enjoy you're stay.
Evan
